Postby
sohc90adel »
https://forums.nicoclub.com/sohc90adel-u5263.htmlWed Jul 30, 2003 5:43 am
I got a lsd differential off a 240 hicas, the thing is i dont know if it is ok to put the differential in my 90 pumpkin. I saw on one of the threads that the hicas pumkin is slightly bigger for cooling? do you think i will have problems? I know i can insatll it with no problems but will it get messed up because of the heat?
Postby
240_Keyy »
https://forums.nicoclub.com/240-keyy-u3357.htmlWed Jul 30, 2003 5:43 am
just use the whole thing (case and all) it should all just bolt right in. Unless it is already apart, then you get to have fun putting it back together...
Postby
sohc90adel »
that is what i mean i only have the differential i dont have the whole pumkin. i know im gonna have to put it all together thats not the problem. The problem is does it matter that i have a 1990 pumpkin instead of the 91 and above hicas pumpkin.
