daniel240 wrote:you need the output shafts from an lsd with the 6bolt patter(2-2-2). they look just like the stock output shafts on the open differential but the inside is different.
so a stock s14 lsd diff should have the 2x2x2 pattern on them?
does the same go for a s13?also is there anything that would need to be changed beside the cover to put a s13 diff into a s14
