LSD acting up
toledo240
After installing my lsd i've notice a big difference.After a month it now starts to leak in two little spots right in the middle ut cant really see where its coming from looking at it under the car. Now if i ride the clutch a little more han i should it makes a little squeel kinda like a mini burnout noise. Where is my problem coming from?
Axel Grungy
Car: 2001 G20 5spd
the only places it could leak is the gasket itself, or the plugs, which i heard your supposed to put some kind of sealant on before you put them back in. i would be sure to check how much fluid is in there, that could be a reason it could be making noise.
btw, do you or jakin have any wheels (two) you want to get rid of?? any wheels will work even stock steelies.
toledo240
Where do i check it from i dont think theres anything to check it. Do I have to go in the process of taking it out?IM not sure if jakin wants to sell any of his wheels ill ask him. I have to keep my extra pair.
