Please explain in detail, at least for the F50.I suspect I'm not the only F50 owner who would like to alter and improve handling.Q45tech wrote:Mostly tires and alignment numbers. Either car can be changed easily except for steering feel/boost/isolation.
I have very recent Bridgestone RE050A Pole Position 245/45/18 tires, which are reputed to be among the best for handling, so not much improvement can be had with tires. I run them at 35 PSI front and 38 rear. You made mention of alignment numbers though. It's my understanding that very little can be changed with respect to alignment on F50s. Can you please elaborate on how alignment can be changed to be effective in improving handling?Q45tech wrote:Assuming F50 owners have the 18" option wheels Michelin PS2 tires in 245/45/18..........inflated to 80% of max cold especially on front.
Assuming the F50 have over 30k new oem shocks front and rear along with new rubber bushings.
Since the questioner resides in Arizona rubber has an extremely short peak life due to heat.................tires and bushings
Since a preponderance of the wheight is on the front, I think your tire pressures should be reversed when not loaded. Might partially explain your car's tendency to understeer. You could go as high as 40 psi in the front.StarPD wrote: I run them at 35 PSI front and 38 rear.
Adjustable RUCA? Not sure what that means.As for tire pressures, Dennis Q45Tech previously suggested running around 3 PSI higher over factory all around, and rears around 3 or 4 PSI higher in rear to increase rear roll stiffness to reduce understeer. I think higher front pressures than rear would improve steering response, but I don't want to aggravate the already almost unacceptable understeer. I had to muscle the car around sharp curves at speed in the mountains on my trip, and we went through a LOT of mountain ranges. My '94 "t" with HICAS was a joy in curves, with just the right amount of slight oversteer to allow accurate tracking in long high-speed curves and beautiful bite in decreasing radius curves. This F50 is a real monster in the same kind of curves, and decreasing radius ones are a real bear. The front end pushes far too much for a car of it's type. Somehow, I HAVE to reduce the excessive understeer. There is no alternate rear sway bar, so that's out of the question. I suspect that possibly the VDS is contributing to the understeer too, but turning it off every time I get in curves is a non-starter. Besides, that doesn't really help much.maxnix wrote:
Adjustable RUCA could set your camber closer to O° to counteract a little of the understeer also.
Okay, so now I need to have special suspension components made to enable camber adjustment. Sounds pretty expensive to me, and I don't have that kind of money. Which parts would have to be custom made to allow for camber adjustment?Q45tech wrote:Adjustable suspension can be created with CUSTOM aftermarket parts or just shims and creativity.
Think nominal front camber is -0.25 which might be 0.5 degrees too little for your tires.........old Q used -0.75 degrees.
Study your rear suspension you will see it is also set mild for tires.
Most performance tires are designed for -0.5 ngative camber minimum with negative 0.5 to 1.0 camber as ideal.
Tires should be inflated based on weight on them.
1.) Adjustable rear upper control arms. Most good and strong ones from aftermarket suppliers like SPL will have one that will accomodate a Q45 suspension.StarPD wrote:1.) Adjustable RUCA? Not sure what that means.
2.) As for tire pressures, Dennis Q45Tech previously suggested running around 3 PSI higher over factory all around, and rears around 3 or 4 PSI higher in rear to increase rear roll stiffness to reduce understeer.
3.) I think higher front pressures than rear would improve steering response, ...
Okay, so do you or anyone else know of anyone who makes an adjustable RUCA for the F50?maxnix wrote:
2.) Never read the part about rear tire pressure requiring higherpressure than heavier front unless load is a factor (2 rear passengers and a trunk full of luggage).
3.) Try it and see what happens. Think about the correlation between load carrying capacity and reduction of slip angles when a tire is at higher psi within its specified operating range.
Q45tech wrote:You are correct however NOTHING can make a 4,000 pound vehicle handle as well as a 3,400 pounder.[NASCAR]
Unfortunately street cars are designed with inadequate front tires [load index] and too wide rear tires to create understeer to avoid power on oversteer...............and to fit into a front end design for parallel parking.
Upgrading the front tires from a 6-7" tread width to a 9-10" width can do wonders.
255/50/16 with a tread wear of 160 and Hoosier Comps with a 40 are still available.http://www.racegoodyear.com/tires/pdf/asphalt.pdf
