LS13/14 Smog
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
Sleeping240
Car: 240sx
So i was curious on what some of you guys with a ls1 240sx are doing with smog. From what I have heard you can go to the dmv and tell them you have a different engine and go through some tests or checks and you get a sticker on the side of you door that says you have that engine. Just kinda through out any info. Anything will help.
Joe
its different for every city/county
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Move or register it at an address where there is no smog/emissions (I've heard of people doing it with PO Boxes to somehow skirt the system.)
Shift_Kouki
Car: 95 Nissan 240SX SE
Also depends on if you're OBD1 or OBD2.... You might be able to pass a simple gas cap / roller sniff test if you have cats on the thing.
Sleeping240
Car: 240sx
i wasn't sure but every state is different, didn't really think about that. I guess here in nevada you can go to the dmv and tell them you have a different (usdm) engine and (as long as its newer than you car) they will point you in the right direction.
Return to “Hybrids”
