autos are gayWDRacing wrote:Look, I'm not a retard and have been building/racing for awhile. My point is this, auto's are not gay and that statement is ignorant at best.
If I like auto's, does that make me gay? No, it means I like auto's and your opinion doesn't matter to me. Simply think a tad before you make a blanket statement like auto's are gay.
If you think that the manual trannies in a Top Fueler are simple manual trannies, then you're an idiot. Using that as an example is lame. I was referring to street level cars, like the GN etc.
WD
You're from Texas...obviously your opinion doesn't countcrzycav86 wrote: autos are gay
Thats the same way I'm going but I ran a -3AN line all the way to the master. I'm still waiting on my Russell fittings.cnichols wrote:
That part # is the Russell fitting that replaces the GM Quick disconnect and has a male -3AN fitting on the end. You have to remove the tension pin first and it comes right out. *NOTE: The Russell package comes with two. One did NOT fit. Not sure if they were supposed to be identical or not, but there was a slight difference between the two. One fit pefect, the other would not go in.
Installed...
The entire assembly off the car. I wanted as few connections as possible so I could limit the possibilities for leakage. All ends are crimped onto the stainless teflon line. I purchased the bleed line as a total package from an LS1 Tech member (steve-d). The length allows for the end to mount near the master cylinder so that it can be bled as the master cylinder is filled and you will never have to get under the car. It also came with an Earl's speed bleeder on the end.
Both lines installed into the slave cylinder...
At the master cylinder end, I used a 3/8"-24 thread banjo bolt with the other end crimped to the line. I believe you can buy this with a -3AN line if you don't crimp it...
Wilwood Clutch Master Cylinder 3/4 in. (Part #:WIL-260-1304) from Summit
Yeah, so did I. The lines you see are both -3AN. When I said you could also buy it with a -3 line, I meant the banjo end instead of having it crimped. Poor choice of wording on my part.574-240sx wrote:
