LS1 - 2 dipsticks?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
kane2g
Car: 92 240sx 95 240sx
LS1 has the hole in the block for one, GTO pan has one too.What you guys use to block the one in the block?????
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Best option is to tap the hole and thread in a bolt with loctite and/or a lock washer.
I already had the engine in by the time I remembered to do this, so I bought a rubber plug that fit snugly...drilled a very small hole in it, and then threaded in a small stainless steel allen head bolt to expand the rubber and make it seal tightly. Another option, although a little ghetto, but effective, is to just use an old dipstick tube and cut it short, then weld up the end or crush it with a vise.
kane2g
yeah, taping the block was going to be my solution.
I was hoping there is somekind of plug that GM uses in GTO that would work
Joe
there is a plug but the gm dealer will just look at you funny.
i also neglected this till it was already in the car, im just using a rubber plug. no problems so far. over a year now.
vaughn4
the factory hole in the block was the perfect size for an 1/8"NPT tap. just put a 1/8" plug in it with some thread sealant on it.
kane2g
Look at me Funny? Yeah, the parts guy told me there isn't a hole there. "Corvette expert" needed to see, but of course any vette on the lot will have headers in the way.
Return to “Hybrids”
