LS swap
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Today I just got my mind blown I just found out LS motors are swappable in the G35's my question is has anyone heard of the LS motors being swapped in the M35?
https://youtu.be/C5_3PeLliTs
Ilya
I have not. The only big motor swap into a Y50 that I've ever seen is Chris Foresberg's VK56 swapped. You can Google that one for more info.
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Thank you sir
chairmankaga
Car: 2007 M35 Base
1982 Alfa Romeo GTV6
If you can swap an LS into a Miata I suppose you can drop it into anything. Sounds nuts. Go for it.
Sstupid
Car: 2007 Infiniti M45 Sport
Vk45de ownz decade-old tech.
Sstupid
How dare you think about putting a pushrod motor in this car.
jiggersplat
Car: 2008 Infiniti M45x
1995 Toyota Supra TT 6-spd
the vk45de IS ALSO DECADES old tech
ArmedAviator
Car: 2012 Infiniti M37x
Sstupid wrote:How dare you think about putting a pushrod motor in this car.
Pushrod motors tend to respond to after-market performance products better, especially when staying NA.
fabM45
Car: 2003 M45
I've thought about doing this as well...how would you integrate the engine management with all of the car's electronic systems?
dragmyr1
Car: 2006 infiniti m35
anyone done it in an M35 yet? I was talking to my friend about finishing my M and the engine and blah blah blah and his mechanic says LS SWAP! he is capable of doing the task with ease. Just wanted to see an update. take care nicofam
EniGmA1987
Car: '06 Infiniti M35 Sport
I would assume you would use an aftermarket ECU, and most likely would also need to put a manual trans in too or at the very least an auto trans made for an LS and a TCU for that trans.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Most likely you'd do it the way Fummins diesel guys put Gen2 6BT's into Ford F pickups. New ECU's, but also retain the original ECU's and fool them into thinking they're still running the show. That way the cluster, ABS etc will still function.
