LPG system tuning
MaxHitZ
Car: 2003 Pathfinder
Small issue, couple pics.. Im not too sure about the wetsuit material used between the gas intake and the plenum. There are 3 3/4" holes located underneath the wetsuit material. It also appears to have a blow off tube from the intake attached also, however i would rather it be offering up to the air box.
Would anyone have seen something like this? Im pretty sure there would be some gas leakage, why im running out of gas after 250kms. (60L tank)
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
If you had a gas leak you would smell it at least now and then.
Only 60L? US 2001 PF is 79L.
You sure the odometer isn't set to miles? 250 miles would be about right for around town.
MaxHitZ
There hasnt been any smell that i can recall, only had her for a week tho. Unsure about the last piece of the puzzle here, LPG was installed in 07 (60L tank, stamped underneath), and it looks 10 times neater than my other lpg cars i owned, then they go and drill some holes in it and put a sock over it.
Definately in kms mate
Chuck Tribolet
'87 Chevy Corvette
Ah not gasoline-powered. Forget what I said about smell and capacity.
Chuck
