Front can actually go higher than stock, max high on the rear is equivalent to about a 1" drop. If you go higher than that in the rear you risk running short on threads in the lower mount.SPIRONIUM wrote:highest setting too please
stock.SPIRONIUM wrote:Thanks! For the rear are you using the stock bottom mount or the Z fork mount?
