Guam180 wrote:I understand what your saying. But I wanna know which parameters will be affected SO MUCH that it will require additional parts to get them back to FACTORY SPECS.
Now I'm no mechanic, but let's say the allowed variance for camber is between 1 and -3 degrees. My car before is at -1.5 and after is -2.5. Its still within factory specs, so I won't need that camber plate...
Now that just leave the question: Is there too many variances to really tell? Suspension Gurus please help.
*Hawaii boys please chime in as well.
when you lower the car drastically, EVERYTHING will change, caster, camber, and toe... mostly camber and toe though. Not so much front camber will be affected, mostly the rears, due to the multi link geometry.
How low are you planning to go?
Most important parts to get a decent alignment are adjustable RUCAs, adjustable rear toe, and adjustable tie rod ends. Camber plates and adjustable tension rods would be nice, but they aren't that much of a priority as the others I mentioned... at least for a decent alignment so that you won't loose too much tire.
