IWannaS15 wrote:Its hard to say how long theyll last. The more you baby them, the longer theyll last.Where did you see the max drop for GR-2s? I'm wondering what max drop is for AGXs??
Max drop under warranty is 1" or 1.5". If you read the lifetime warranty, they void it over that amount. Max doable? I probably wouldn't go lower than the sportlines since I think the dampening/spring rates and all that goodness get affected and your ride won't be as nice.
I've heard from other members who have run the agx for 5 years or so w/ no problems (but I don't know if it's w/ sportlines or pros) and they probably didn't drift to work and home every single day .
So, if you have pros + agx, you're set for life, even when they blow up, as long as you have something to ride on in the mean-time & the original receipt, kyb will hook you up.
