onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Jun 04, 2008 3:38 pm
Then you should understand that EVERYTHING is built around the car @ it's current height.
If you want to talk idealistically and isolate just the lowering - you compromise handling even lowering the car 1/10th of an inch. However, coilovers, shocks & springs, or whatever you like compensate for the decreased handling by providing better shocks, roll center, whatever you like.
If you want your car to handle the best for a certain height, you either need specialized tools to measure roll center, etc, or getting it aligned/balanced/etc by a professional shop.
Sorry to tell you, but the vast majority of people on this forum won't be able to give you an exact #. How well a car handles depends A LOT on the driver as well - i.e. some like certain alignments, some like certain heights, some like certain tires/spring rates, etc. There is no single "catch-all" optimum suspension setup.
Realistically will you notice the difference in handling of your car between 1.5" lowered & 2" lowered? I seriously doubt it.
If you want a #, I'll give you something:
front - as low as you can get where at full compression nothing hits the wheel well/fender.rear - matched w/ the fronts.
For my car, that's around 2-3" lower than stock.
You can just do what most track guys here do (I've done this as well), test your car at different heights/alignments & find out what works for you.
