Lowering Springs
pherman2000
Car: 2000 Nissan Maxima SE
How much work is needed to install a set of lowering springs? I have a 2000 max and was wondering if it could be done on my own or if I should go somewhere for it.
blazncypher
Car: 01 I30
you need a machine to compress your springs before you can install them.
lightsout
Car: 00 Nismo Maxima SE
blazncypher wrote:you need a machine to compress your springs before you can install them.
You are able to do this yourself without a spring compressor, or you can purchase a spring compressor. I believe that Kragen or Autozone will Rent tools like these to us shadetree mechanics!
NOTE: it may help to remove your brake rotors to give you more working clearance.
1. put up the front of the car on jack stands.
2. put the hydaulic jack/lift under the suspension and raise suspenesion right up to when the car starts to lift off the jack stand.
3. remove the strut bolt under the hood(bolt in the middle, not the 3 surrounding)
4. slowly let out the jack until the suspension is hanging.
5. unclip the brake line and speed control line from the strut.
6. remove the 2 large bolts at the bottom of the strut.
7. wiggle the strut until it slips out.
8. remove the stock spring and install new spring over the strut...I would advise you to purchase Tokico Blue Struts b/c you stock struts are probably shot and will give you a junky ride if they are not replaced.
9. put the new spring on
10. tighten the 2 bottom strut bolts
11. line up the top of the strut with the mounting hole
12. start to compress the suspension with the jack little by little until the top of the strut is able to receive the nut.
13. reconnect the brake line clip and speed sensor clip.
rxm6
Car: '93 240sx
Like lightsout said...do it yourself. The first time I ever replaced springs was on my i30. Took me 12 hours but I got it done and saved the $450 that shops wanted to charge me If you need a walk through (with pictures...they help) I have one bookmarked on my laptop and I'm sure i can dig it up for you if you need it. GL.
lightsout
good look'n out rxm6
pherman2000
so will I have any problems with wheel clearance? I have 19s with 235/35/19 tires.
rxm6
Car: '93 240sx
pherman2000 wrote:so will I have any problems with wheel clearance? I have 19s with 235/35/19 tires.
I don't think so...but I wouldn't go with an overly aggressive drop more than 2 inches. Go with a 1.7 or a 1.5 drop I think and that will get you were you want to be.
lightsout
http://www.stillen.com/product...AXIMA
take a look here!!my stillen connection is Kenny in sales @ 1 800 579 2131 x185tell him Devin from San Diego referred you if you call!!
