LOWERING SPRINGS?
[email protected]
Car: 2002 NISSAN MAXIMA SE
WHAT KIND SHOULD I GET?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Check your thread in the Maxima forum, and damnit, turn off the freakin caps lock!!!
[email protected]
how you get that picture on here
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
That picture? It's called a sig, check your profile and edit it. Keep the size within reason.
[email protected] wrote:WHAT KIND SHOULD I GET?
The right ones. Check tein and eibach. There are probably 10 other name brands out there that make lowering springs for a Maxima. Time for you to do some research and decide which ones are right for you.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Oy....caps lock isn't necessary.
[email protected]
what does progressive mean
audtatious
The more they compress the stiffer they get. Thus they are a progressive rate.
[email protected]
is that good or bad
audtatious
Good unless your suspension bottoms out first.
[email protected]
what kind would you get
audtatious
Dunno, but I've only driven with Eibachs and they are too stiff. Hit a few potholes with those 20's and you will be dealing with a steering wheel shimmy.
[email protected]
is that right so basically iam out of luck. the stock suspension is the same way
audtatious
The stock suspension is soft compared to an eibach-equipped suspension.
