Is this the set you're referring to being gone?oldmako wrote:Gennimens,...................................
Kevin Falk has some Teins available, and I have talked to Joe about oleo's and rubber. It sounds as though stock struts will work with the Tein springs. I missed out on the KYB's, and don't care to blow 800 bucks on them at full fare. Snooze ya lose. ................
Modified by oldmako at 9:23 PM 1/3/2008
Modified by oldmako at 9:25 PM 1/3/2008
On large, heavy, luxury cars it's purely cosmetic if you ask me.Q45tech wrote:Mechanically or technologically, lowering offers zero advantages.Lowering the Center of gravity does reduce the transfer weight but not significantly:
21" vs 20" is 5% but this is mitigated by the track width to less than 2%.So 15-30 pounds less at worsecase highest G load on an already 1500 pound loaded tire.
The parallelism of the tie rods get out of whack which creates a toe bump steer weirdness in anything but a perfect glass smooth road.
Body roll is just that body roll and has little effect on weight transfer to the tire.................stopping body roll does nothing as the same weight is still transferred.
If you found one of the few second generation Qs which the previous owner was diligent enough to change over all the rubber components before selling his or her 8 year old car, and you were able to purchase that presumably otherwise immaculately maintained Q for that price, you are indeed lucky. If, however, your car bears the original rubber components (suspension and otherwise), I would say your car was purchased with the same flaws as the OP's, only you haven't taken the time or effort to address them.RAP wrote:No flames but
I am wondering what prompted you to buy a 1999 Q 45 with seemingly so many faults? Maybe you like a challenge ? ? ?
I recently purchased a 2000 for a really good price $ 8751.00 and there are more available if you shop around the country. I found mine thru Ebay from a private seller located in Florida. I'm in LA.
My car is virtually flawless at 92000 + plus a little. This is an eight year old car.
I can't really help you with your current question but it seems to me that your intentions for the considered repairs that your car needs and, will need, will make buying one with no problems a steal even at a higher price ? ? ?
Your situation might well be a good example of "not how to do it" for someone, in the future, contemplating purchasing one of these cars. Really the point of this post. Unless they are into working on cars and spending a lotta cash of course.
In any event, good luck.
JackJack
And you would be wrong not to recognize that the rubber has degraded significantly due to age, UV, salt, but mostly heat and ozone.RAP wrote:I also think that the "rubber" should and will last longer that eight years.
What are their differences? Y33 vs. FGY33... I was under the impression that it was just semantics. Aren't they the same thing? Falk's Q was a 98T right? If Duy's Q is a 98 and a FGY33 then the whole thing is confusingmaxnix wrote:...........The Teins that Falk sells are for a Y33, not a FGY33.......................... I watched Duy take his 1998 FGY33 over elevated entrances sideways all the time. ..................
No I believe they came with the VQ30DET (not sure about the turbo)ddrumman wrote:OK then.
Did the Glorias and Cedrics also use the VH41DE?
When the time comes to replace whatever, I'll replace. The car I bought spent it's life in FL driven by a 60 ? year old gentleman, well moneyed . He didn't shy away from the dealer either so I suppose if the car needed to have anything done it would have been done. The guy even did an oil change, had the rotors turned and pads replaced, at his expense, prior to delivery after I had sewed up the deal. I just received an email from the guy two days ago asking how the car was doing. Can you do better buying a secondhand car? ?maxnix wrote:And you would be wrong not to recognize that the rubber has degraded significantly due to age, UV, salt, but mostly heat and ozone.
Why (and it is obvious upon disassembly) we always recommend replacing all rubber in a suspension system and the front strut bearings on the FGY33.
It all goes to your tolerance for wear and imperfection and your fondness for paying for repeat labor to "save" a buck.
1.) OEM maintenance programs are designed to get the car past the original OEM warranty so when the big stuff breaks, it is the owner's dime. Q45tech has pursued a more aggressive than OEM preventative maintenance schedule, and the results are here in his previous posts for all to evaluate. Nice to have a car with 330K+ miles that performs as good as new, expecially when it is a Q45. Even the decontented (but imporoved in some ways) FGY33.RAP wrote:1.) When the time comes to replace whatever, I'll replace. The car I bought spent it's life in FL driven by a 60 ? year old gentleman, well moneyed . He didn't shy away from the dealer either so I suppose if the car needed to have anything done it would have been done.
2.) IT'S A SECONDHAND CAR. And it's perfect considering.
3.) Furthermore I am not into "wringing out cars"
4.) I will, soon, start poking around underneath this fine vehicle and see about the rubbery state of affairs. I promise to repair and/or replace any and all parts that are affected by the "ozone" or lack thereof, O SUSPENSION MASTER
