Lowering Springs + KYB Gas A Just Shocks
DoubleDown
Car: 2001 Infiniti QX4
I have a 2001 QX4 that I am looking to drop, have been doing a bit of research and decided to go with the lowering springs off of 4x4parts (2" drop)https://www.4x4parts.com/catal...d=153
Along with the KYB Gas A Just Shocks.https://www.4x4parts.com/catal...=4806
My question is will these shocks be stiff enough to stop me from bottoming out in the back everytime? All that is in the trunk is a ported sub box with 2-10" subs. Weighing roughly 50lbs?
01-QX4
DoubleDown wrote:I have a 2001 QX4 that I am looking to drop, have been doing a bit of research and decided to go with the lowering springs off of 4x4parts (2" drop)https://www.4x4parts.com/catal...d=153
I'm not totally familar with the 2" drop springs. However I did have (for a VERY short time) a pair of KYB Gas A Just Shocks installed on my 2001 QX4 with stock springs. They have been off my QX4 after I had them in for about a week and approximately 200 miles of usage. I had loaded up the trunk/cargo area fully (about 300lbs of cargo) and with the maximum occupants (5) people in my 2001 QX4 and it DOESN'T bottom out at all.
In fact in you want to save some money I have them for sale at $85.00 shipped! I have them for sale here >> zerothread?id=473378 PM me if you're interested.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Ok well i have the 2" lowering springs on my 02 pathy, the gas adjust shocks in the back and the kyb-gr2s up front.
i also have a sub box and an amp in the back, and you dont bottom out, but the spring rebound rate is alot higher than stock, so it might feel like it, since if you go over a decent sized pothole your a** will leave the seat about 3 inches.
Pwnin O'Brien
miamiheat3332 wrote:Ok well i have the 2" lowering springs on my 02 pathy, the gas adjust shocks in the back and the kyb-gr2s up front.
Did you have to remove the factory bump stops so it wouldn't bottom out all the time?
miamiheat3332
No i actually didnt, i did see that it was pretty close to the top of where the coil sits with that bump stop, but i cant hear it bottoming out or it doesnt feel like it cause i had that with my OEMs in the back cause they were shot. these coils are alot thicker and harder, and the spring rebound rate is high.
DoubleDown
What size of tires are you running? I am almost 100% sure I am going to have to roll my fenders as the 265/40/22s (30.5") will rub? They are only 0.4" wider in overall diameter then my winter tires (255/65/17).
miamiheat3332
i have 255/65/16 pirelli ice and snow tires on my pathy at the moment, and its lowered and there is no rubbing anywhere.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Another thing is you cant roll pathy/qx4 fenders cause its a molding and if your are going to go with 22's I justice you go with 265/35r22 as it is similar diameter as the original wheel
I order my springs on Jan 29 and still not shipped yet .Miam I'll be the first one with Lowering springs and 22;s
miamiheat3332
if you get your springs haha :p, and 22"s your probably going to F up your fenders pretty nice especially if they stick out of the wheel wells, and since there will be almost no space between the fender and tire, you go over some bumps and it'll rub really nice. im getting 20's and they are going to stick out past the wheel wells but there will be more space so i think im pretty safe.
Modified by miamiheat3332 at 10:57 PM 2/6/2010
JonathanPrem
My wheels dont stick out.... I think. I want it to be really flush and mad low type of look. I dont mind driving slow and turning low.
Modified by JonathanPrem at 8:29 AM 2/7/2010
miamiheat3332
oh i see then, i thought it looked like they did stick out, i want my 20"s to , not too much, but i like the wide aggressive stance look.
JonathanPrem
Same man. I want my truck to be HellaFlush and btw how long did it take you to get your stuff shipped to you. its been more then a week and still not shipped
JonathanPrem
Got me Springs today and getting them installed this weekend . And 4x4 didnt lower the price and got raped on duties
Modified by JonathanPrem at 11:07 AM 2/12/2010
miamiheat3332
nice. put some pics up, but i still had these first buddy, cant compete with that haha. and thats why living stateside is nicer
sixty4
Car: 2008 QX56
1964 Lincoln Continental
Gone:
2006 QX56, 1998 QX4, 2001 QX4, 2000 I30
I have 22" on my 01 QX4 (http://www.cardomain.com/ride/2509499 w/ 265/35ZR-22 Goodyear Eagle GT XL), and you really need to know your offset (I'm at 18 I think) with them before you lower the vehicle anymore. If you have the 22" now, turn the steering wheel in either direction all the way and check the clearance. I have about an inch and a half that still clears even with shock travel. I would also do the same in reverse and see what you have as well.
Depending on where you live I would never put 22" on a vehicle mid winter. I know from experience killing one a couple of weeks ago taking way too much time to remove them. I went ahead and put some tires on my QX56 wheel modification.
Modified by sixty4 at 10:14 PM 2/12/2010
exvin
Car: 2000 Nissan Pathfinder
JonathanPrem wrote:Got me Springs today and getting them installed this weekend . And 4x4 didnt lower the price and got raped on duties
Are you saying that ur ride did not lower after installation? Did allow th springs to settle first?
Pwnin O'Brien
He was just saying that he couldn't get 4x4parts.com to lower the price of the lowering springs and he ended up paying more due to the necessary duties (for Canadian residents).
