Lowering Springs and Camber
4DRSS
I'm considering lowering my Versa, but had a couple questions first. I am looking at the Tanabe NF210 springs which offer a 1.5" drop. Is a camber kit required? If so, who makes one? Second...how is the ride quality, especially with 4 people in the car?
Thanks!!
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
no camber kit required......I ride with my wife and three daughters all the time with no issues
4DRSS
bulld0g wrote:no camber kit required......I ride with my wife and three daughters all the time with no issues
Thanks for your input. Did you have your alignment checked after installing the springs?
blindsnyper
Car: 2007 versa
yyyeeesssssi love mine, not stiff at all
4DRSS
Anyone else? Just want to make sure I'm not gonna chew up tires.
bulld0g
4DRSS wrote:Anyone else? Just want to make sure I'm not gonna chew up tires.
I have put over 20K miles on my tires since lowering it with no adverse tire wear
07V84Z
Car: 2007 Versa~Silver, Hatch, 6Spd 1984 300ZX~White, 5Spd, N/A
when changing suspension components ALWAYS have the alignment checked! you shouldn't have any issues. my V isn't lowered (yet ) but my 04 Sentra is, and no tire problems. you should be fine, go for it.
biggie
With just a 1.5" drop the stock alignment adjustment should be able to cover the amount of camber you need. The coilover setup on the car may be a whole other issue, haven't seen anyone with those yet though.
manvan
Car: versa hatch
yeah, get your alignment done, its worth it though, helps tire wear, any who definatly lower the car, it doesnt look like a minivan after, ive been getting complements ever since, look at codereds how to, its real good, and beware the doing the front, back takes 20 min, the front takes a while, spray it w pb blaster before you do it and let it sit for an hour
4DRSS
manvan wrote:look at codereds how to, its real good, and beware the doing the front, back takes 20 min, the front takes a while, spray it w pb blaster before you do it and let it sit for an hour
I can't find this how to... will someone post a link please?
manvan
Car: versa hatch
manvan
Car: versa hatch
my bad, its by bulldog
4DRSS
Awesome, THANK YOU!![
4DRSS
Installed the springs and had the car aligned, so far very pleased! Camber was fine, the only adjustment that was out of spec after lowering was the toe. Car looks 100 times better!
manvan
Car: versa hatch
i know, alot of people say the car doesnt look the same at all
4DRSS
I had one other question reguarding the bumpstops. Tanabe recommends cutting 15-25 mm off them, but I didn't. So far no problems with bottoming out. Did anyone cut theirs?
manvan
Car: versa hatch
nope, mine is uncircumsized
