lowering spring troubles!
BOOM_STICK
Car: **1987 Toyota MR-2**
i installed coilover lowering springs this weekend in a 89 240sx (not top of the line, G2 or GZ or something) and the front of my car bounces when i hit even a little bump. is this normal? will they break in over time? is there anything i can do to stop/lessen the bounce? can this hurt my car?
this is my second car, not a lot of money, little experience, and my dads a carpenter, i'm kinda stuck.
thanx
Modified by nismo_89_240sx at 1:39 PM 11/7/2006
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
lowering springs in general will cut down the life of stock shocks in no time. you need shocks that can tolerate the load placed from lowering.
onosqv
Car: '92 240sx Vert
your shocks are probably blown now. put the stock springs back on.
BOOM_STICK
new gas struts 3 days ago, hopefully not blown
onosqv
Car: '92 240sx Vert
then just put the stock springs back on before they become blown.
jdm_master_X
nismo_89_240sx wrote:new gas struts 3 days ago, hopefully not blown
if they are KYB GR-2s, those wont hold well either. what brand?
adrianfromthecastle
Car: 1992 Nissan 240sx
nismo_89_240sx wrote:i installed coilover lowering springs this weekend in a 89 240sx
umm... coilovers and lowering springs dont belong in the same sentece unless theyre in comparison...
wankelTII
The spring rates and the valving in the shocks dont work well together. Either get some springs that were designed to work with the stock shock valving, like eibach PRO springs or save up and buy some 2 way adjustable shocks that allow you to adjust the bound and rebound seperately. The shocks WOULD be a much better choice BUT because you bought crappy springs you dont know the spring rates and you dont know if they are right for your car.
Either that or your shocks are blown, how low is the car?
BOOM_STICK
sorry guys, im retarded, found out you have to cut the cap over the strut body to slide the threaded sleeve over. works much better. the struts where monroe i think.
thanx for all the info, ill know next time.
nightkid86
Car: 97 S14 SE
how much were these "coilovers"
actual coilovers start at around $600 for non adjustable ones
BOOM_STICK
well..... i bought them from my friend at work for about $50. they are ajustable, the problem is they are just generic, not specificly ment for a 240sx, so they dont really lower the car. it just sits a little below stock at lowest setting, but provides a stiffer spring. it handles better now so i think ill keep them for a while.
just remember am a unexperenced 17 year old with no money, so i buy "generic" stuff and make it work. im creative like that.
nightkid86
Car: 97 S14 SE
What you bought arn't coilovers, and they are just going to blow out your shocks. Since you are a just an unexperienced 17 yr old I would say start saving up to buy "real" stuff and really make it work.
adrianfromthecastle
nightkid86 wrote:What you bought arn't coilovers, and they are just going to blow out your shocks. Since you are a just an unexperienced 17 yr old I would say start saving up to buy "real" stuff and really make it work.
i agree... suspension is something you dont wanna cheap out on, you dont wanna be on the side of the freeway 11 oclock at night because your suspension fell apart on you. imo, your better off with stock suspension until you can actually save up for some real stuff [safer too].
BOOM_STICK
thanx for all your guys advice. problobly gonna switch back to stock when i get some time.
damn i wish i had some money
thanx again
Modified by nismo_89_240sx at 12:09 PM 11/11/2006
