lowering question?????????
samandfiz
Car: nissan 240sx
bought some 17"x7" sentra v specs and put on my s13 and now im thinking about lowering the car a little bit more no more than 2".
1. is this going to work will the car have clearence to steer and do its thing2. if needed what do i need to buy othere than shocks and struts
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
1. Yep, you'll be fine 2. You should be good to go. Just remember that when you lower the car, your camber will only be able to be adjusted minimally. The solution to this problem is to buy aftermarket, adjustable RUCA (rear upper control arms) such as those sold buy our own [url=http://www.SPLparts.com]
-Dan
samandfiz
Car: nissan 240sx
thanks i like your s13. what year is it?
JeromeS13
Car: 2008 Subaru Impreza STI
Ummm, dude. Dan has an S14....
And, don't forget about eccentric bolts to adjust the camber up front
-Jerome
samandfiz
Car: nissan 240sx
sorry i they were all his cars in the little picture click thing on the bottom thanks for reminding me of that i dont mess around with suspension alot
