Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Oct 15, 2008 3:46 am
I haven no idea except that Nissan was trying to get some weight balance towards the rear. Check out my Murano wheels thread and you'll see the visible difference between the front and rear fender gaps.
The only need for a camber kit will be if you cannot achieve the camber setting that you want with the stock eccentric bolts. There's not a hard and fast drop limit that requires a camber kit. It all depends on how much neg camber you want to run.
