lowering on stock springs?
bigbumpinZ
Car: 1994 300zx LS1 Turbocharged, 1994 300zx NA, 1992 300zx Twin Turbo
im planning on lowering my NA pretty soon im not going to be doing anything crazy with it just cruising around can i run stock struts with lowering springs. everyone has different outcomes i just wanna see if anyones got anything special
NolimitZ32
Generally its not a good idea but depending on that springs you are putting on you may, basically if its a .5-1.0 inch drop than you should be ok but if you are gonna slam it (3"+) Id say you need to go ahead and get coilovers.
bigbumpinZ
i was planning on doing a coilover set if i completly slammed it, im just hoping if its dropped about 1" the strut wont blow out if i keep it stock
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
It probably will blow, the struts are designed to travel on stock springs.
bigbumpinZ
ya i looked into that after posting my last comment, coilovers will probably be alot safer and i can get more drop out of them. now for the next question who makes a good set of coilovers that will be a comfortable ride once i lower it
daxnizmo
Car: 90 300ZX 2+2 NA, Auto
I'm on Megan springs with stock shocks/struts. The drop is nice, the ride good, and I like it. No issues with a blown one yet and it's been about a year. Keep in mind tho if you lower the car too much, you'll need at the very least, FUCA's and RUCA's for chamber issues.
bigbumpinZ
how much was the drop you did? as long as it can ride nice and i wont have serious issues ill be happy im not going to be using this for crazy performance or anything
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Also, did you do new struts when you went to the Megans? If they were new, then they would have broken in on the Megan height and travel. 100K+ miles on the stock springs though, and the struts get used to the certain travel and height. Drop them lower and force the part of the strut that's been exposed for years into the soft seal, you're almost guaranteed to blow the strut out.
daxnizmo
bigbumpinZ wrote:how much was the drop you did? as long as it can ride nice and i wont have serious issues ill be happy im not going to be using this for crazy performance or anything
I got a good 1.5" t0 2" all the way around. The wheel to fender gap is gone completely but it's not tucking tire. The ride IMO is better than my stock shocks. It's not bouncy at all, nice and firm but doesn't beat you up. I love the ride quality! And the Louisiana roads are some of the worst in the nation!
Ace2cool wrote:Also, did you do new struts when you went to the Megans? If they were new, then they would have broken in on the Megan height and travel. 100K+ miles on the stock springs though, and the struts get used to the certain travel and height. Drop them lower and force the part of the strut that's been exposed for years into the soft seal, you're almost guaranteed to blow the strut out.
Yes the struts were new when I went to Megans, so the break in was on the Megan's travel. I've had them on for quite a while with no issues as of yet. Like I said, I love the look and ride. Just perfect for someone looking for a nice drop and for a decent price.
Before:
After:
madmax3040
Car: 1993 300zx
With the Megans did you replace FUCA and RUCA? Tension Rod. I looking to do the same drop.
Fairladyz96beast
Car: 96 300zx z32
So my question is did you haeto " cut anything your did it sit perfect an whats the exact hight you lowered the z at
Before:
After:
Image[/quote]
Fairladyz96beast
Car: 96 300zx z32
So my question is did you have to cut anything or did you do the loweri ng springs an sat perfect an how lownexacly did you go
