240tek »
https://forums.nicoclub.com/240tek-u12526.html
Sat Feb 28, 2004 11:19 pm
I think the suspension will do you just fine as your first foray into drifting. I can guarantee you, though, that if you continue to drift, you'll start wanting a stiffer setup. Tein coilovers are excellent, but costly. Koni Struts will suit you pretty well, pair those with a nice stiff set of strings and you'll be set. Again, that's later down the road though. I'd suggest you get the pro-kit/blue set up for now. As you start wanting more stiffness, instead of going right for a stiffer spring/strut set up, add a rear lower strut bar, bushings, camber kits since they're cheap, then dump the cash for a stiffer set up if you're still into it. PEACE. Tek.
