3" drop will leave you with a camber you cannot live with. Even the 1" -1.5" drop of my Eibachs result in a -2° camber that decreases rear tire life seriously. A few of us are having SPL fabricate some RUCA to correct this.
You need to find Eibach of Espelir springs for the FGY33. The Teins are made for a Y33 and are not strong enough.
You need to go to
http://www.memoryfab.com and order the KYB SR Specials for the FGY33. It will take 6-8 weeks for them to arrive from Japan.
When you get your parts, check back and we'll give you some other suggestions. Gaiters and front strut bearings for sure. Maybe front strut mounts, spring seats, front anti-sway bar links, probably steering rack bushings, anti-sway bar bushings. Same things on the rear. Depends where it's been, how long it's been there, and how it's been maintained.
Modified by maxnix at 7:36 AM 6/19/2009
