So I've searched around and been looking at lowering my sedan a little cause I hate the wheel gap. It seems from what I've read that most people go with coilovers, but they would be worthless on my car. So I've been looking at static drops. I only want about an inch lower as that should eliminate a good amount of wheel gap and leave room for larger diameter wheels later on.
What I need to know is, what is a good spring to lower on. Tien? H&R? Eibach? And are any of the springs a minimal enough drop to still use factory struts or would I really need to switch over to KYB? I'm going to check tonight at work to see if we carry KYB for these cars or if they are something we have to order. If we carry them, I can probably get a full set for under $300, so eventually I will swap over to better struts. I just need to know if its a huge necessity right away.
