Bozo954 »
https://forums.nicoclub.com/bozo954-u166440.html
Thu Aug 19, 2010 4:41 am
Here you go, JHW, the data from........next post - camber results (if possible; it's a PDF).
BTW, the entire job cost me $600.00. A steal if you ask me. (Springs $400, Labor $150, Alignment $50)
Not to mention I've had the car since Nov. 2006, i.e., I purposely waited until the 4 year warranty was just about expired to really start the aftermarket stuff. (It's just a Monday-Friday daily driver; only about 24,800 miles thus far.)
Anyway, that way I don't have to listen to any of that "voided warranty" bulls...........never mind. But, it's on now.
Gonna try to up my performance and better my front-rear balance by losing some weight in the rightp laces.
Maybe upgrade the shocks, although not an absolute necessity due to spring rates not drastically changing with the Tein HT 350Zs (and for about the same price).
Then, come the power-adders under the hood.
Whatever you decide, good luck.
2006 G35 Coupe Spring Rates w/sport suspension:
FRONT: Same spring rates as stock - 314 lb.
REAR: Spring rate increase of 24% - 427 lb. (from stock 342 #)
So, after doing alot of research and in the interest of 1 and 2:
1) Not wanting to need a camber kit for more than a .8 inch drop to get back to mfg. spec, and
2) Wanting to keep spring rates as close as possible to sport-package or sport-tuned suspension spec.........
My next mod:
TEIN "H-Tech" Peformance Lowering Suspension Springs 03-08 Nissan 350Z
Spring Rate Front: 358 lb./inch
Spring Rate Rear: 375 lb./inch
Ride Height Lowering Front: 350Z - 0.3 inches (7mm) / G35 Coupe .08 inches
Ride Height Lowering Rear: 350Z - 0.2 inches (4mm) / G35 Coupe .07 inches
(Will post pics when I'm done.)
AUGUST 2010:
Had Tein 350Z "H-Tech" Springs installed a few days ago..........pics later.
Alignment went back to within manufacturer's spec or acceptable range,no camber ket needed.
Springs seemed to have settled, and while noticeble to me - especially from behind the wheel, the drop is barely noticeable to the untrained eye.
Whatever.
Bottom Line: Now I have a PROPER sport package, and the lower ride combined with my Rear-Active Steering, the BMW 3 - even this generation - is beatable at all times. No more weaknesses in my setup to exploit. Brang it onnnn!!
Not to mention, I don't know what Nissan-Infiniti engineers were thinking when they decided to only up rear spring rates in the sport-suspension package, but who cares?
Rides better, handles better, accelerates smoother w/less drag (duhh!), no noticeable negatives regarding the different spring rates, etc........yet.
I've heard I may get more body roll, but haven't driven it hard enough to notice.
Again, whatever. I'm good!!
NEXT MODS:
*Tokico HP Blue Shocks/Struts
*SEIBON OEM Carbon Fiber hood (from my research, saves about 20-22 lb. from stock bumper)
*K&N Cold Air Intake & Air Filter
