RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Thu Jul 20, 2006 7:42 pm
Welcome aboard, Brian.
Folks are dropping there X's, but the only problem is, there is NO aftermarket support for shocks/struts. Most used the unvevised springs from a 350z. Drops the X about 1.4". The only concern with dropping the x, is that the shocks/struts will wear out alot faster because of the shorter spring and they will be under dampened. At least with the RWD sedan, there was a Sport Suspension, like I have, that accomodates shorter springs better. Tein S tech, H techs are also available, but will give even more of a drop. Lastly, making sure you can get the alignment close to specs is going to be tricky also.
