Lowering datsun 720... i am stumped. Please help!
Bubbas Garage
Car: 1984 Datsun/nissan
Hello everyone, got a quick question. I have a 1984 Datsun/Nissan 720 pickup. I lowered the front by cranking down the torsion bars. And i got ready to do the rear end. Got the u bolts all taken out, and jacked up the rear end. But, instead of the rear end and the leafs seperating... they went together. Then i notice that there is a bolt coming down from the rear end going through all 3 leafs. So, i loosend the nut and they are now sepereated.. But the bolt comeing down from the rear end makes me not able to put in the blocks? So what should i do? Can i still lower it? Do i have to do it a different way? I am stumped.. Any help would be appreciated. thanks!
Jordan :gotme
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
I don't have a 720, but on my hardbody, there is a bolt in the center that holds the spring pack together. This bolt stays in place, the block has a recess that centers it on the spring pack where the bolt slots into it. You are saying this bolt is attached to the axle itself?
Hope someone else can help, this is beyond me.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I threw my 2 cents in your other thread that is in the Datsun truck section.
longtooth
Car: 89 d21 HB
Should be a bolt on each leaf pack called a centering pin. That should not be removed unless your replacing or adding leaf springs.
You should only have to remove the u bolts and/or shocks. Raise the axle off of the leaf spring and install the block. One end should have a post and the other should have a recessed hole for the center pin to fit in. Now you should be able to install the bigger u-bolts.
I hope I understood you correctly and answered it for you.
Bubbas Garage
Got the problem. Bolt was rusted in the hole in the axle, so it looked like it came out of the axle. Got it all done now :)
Will post pics if you would like
MilkMan
Car: 97 Hardbody
:worthless: :gapteeth:
Bubbas Garage
1984 Datsun/nissan. 3 inch blocks, torsion bars cranked down.
[img]file:///Users/JB3021/Downloads/Photo028.jpg[/img]
[img]file:///Users/JB3021/Downloads/Photo026.jpg[/img]
Bubbas Garage
http://www.cardomain.com/ride/3921266/1 ... 720/page-1
Got it! Click on the pictures to make them bigger!!
Bubbas Garage
going lower this weekend. gonna remove middle leaf, and crank torsion bars down the rest.
