S13Drifter wrote:If you only want to have 300hp part of the time (i.e. drag racing) then nitrous oxide maybe the answer. But if you want 300hp all the time then you are going to have to go turbocharging. To be safe you are going to have to go pistons and rods. I have heard people breaking at 10psi with stock compression so at 12psi on lowered compression may be pushing it. If you lower compression, have FMU, and the ignition is correct you would be running a risk and i personally wouldn't do it, but i think you might be ok. Movingviolation240 knows more about this than i do so if he thinks you will be ok then i'm sure you will.
The KA does NOT need rods or pistons to be safe. We have all witnessed several KA+Ts that are doing fine on stock internals up to 16psi. Fuel and tuning are the safegaurds when going turbo. If you wanted to blow extra money for the added assurance, that's fine, but it's money that could go somewhere else. Besides, a 9.5:1 turbo motor is much more liveable and driveable. People break at lower boost because of tuning issues, not because they're just putting out too much power.
