lowering comp question...
e_c
Car: 1990 240sx
i am going to rebuild/builp up a KA-E motor to turbo it, then swap it in my 1990 when im finnished building it. if i get thorugh the build/port polish/ everything else and i use lower compression pistons (because of the turbo set up) but my current engine craps out, can i use the built engine with no turbo for a while until i finnish getting all the turbo parts... so basically i will be running a turbo built block with lower compression in a na format until i can get the turbo on... may be a while thoughwill this cause any problems or is there anything i should be worried about?
TheOne
Car: 93 240sx FB
it should be ok, cept you will feel it with less hp cause of the lower comp.
e_c
Car: 1990 240sx
thanks for the quick reply
wild_maxx
Car: 90 TT pearl yellow z32
thats not a bad idea to run na for a bit. get the motor all broken in and whatnot. then you will really love it when you turbo it.
veilside180sx
unless you lower the compression ratio lower than the standard boosted 8.5:1, you won't notice a difference because it's already a 8.6:1. Which isn't enough to tell.
I guess if by the rare chance you have a early '89 with a 9:1 motor you may be able to tell a little bit.
