lowering=broken spindles?
KC240SR
Car: 92 coupe w/ blacktop SR
Ok, so I'm going to be trading my friend some subs and an amp for his Eibach springs and some struts and some other stuff, and when i told my parents about this they must have asked someone about lowering cars because they come back to me the next day and said I can't do it because someone told them you can break your spindles by lowering your car. So I was like "WTF?!? I've never heard of this" But they will not move on their position. I have friends with they 240s slammed like 3 finger gap from the ground and stuff, and they've been running like that for a long time. So basically what I'm asking is if there is any truth to breaking your spindles from lowering your car?
nwmrkt
Car: S13
lowring your car could cause more "wear-and tear" on some parts. But iv'e never heard of the spindles breaking.
95_240
Car: 1995 240sx
I've never heard of a spindle breaking from lowering a car. I've only seen aluminum ones break and thats usually because someone can't drive.
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
yea it should be fine, you really only wreak havoc on the struts.
yokota180sx
Car: 1997 Stagea RS4, r34 front
incorrect!
You cause havon on-Tension rod bushingslower balljointstie rods and tie rod ends
and every bushing in the rear gets tweeked
regardless. for your drop, NO nothing will be damaged
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
tell them to not ask mini truck owners.
on most pickups, s10's for example, you can lower the trucks by use of aftermarket spindles which actually raise the axle point on the spindle therefore lowering the vehicle.
being the spinle/axle is one piece, if you by a cheap one, they can brake. or if they are installed wrong they can break.
you arent changing out you spindle, or modifying it in anyway.
show/tell your parents. get some truck magazines, and some car mags, and show them the differences.
hope i helped.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
I am pretty sure they talked to someone who thinks you are going to airbag or hydro your car. If you do those things yes you will break spindles and other parts. Dropping your car on springs WILL NOT cause breakage of those parts.
Anand
Car: 95 Nissan 240SX
listen to your parents
you will break your car in half
I keed I keed
Nothing will happen to your spindleslol
AceInhole
yokota180sx wrote:incorrect!
Hence you reset bushing positions and re-tighten everything with the suspension loaded :P
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
ca18datsun510 wrote:tell them to not ask mini truck owners.
hope i helped.
uh, doesn't matter. If you drop an S13 (don't know about S14's) more than an inch, you bottom out the suspension, misalign everything to the point that you need adjustable suspension pieces to get it right. The Eibach springs lower more than an inch (prokit and sportlines). Yokota is right and anyone with a lowered 240 can attest to this as well.
S14toRPS13
That's why we're all in search of new spindles to replace our broken ones. Since when did your parents become 240 experts.
Anyways, Eibach sportlines will only be good enough to give you that "not quite 4x4 look".
ZiG
Car: 1993 240sx coupe
The only thing you will have to worry about is being injured in an accident more easily due to the fact that your bumpers and doors will be lower than EVEN MORE of the other cars on the road.
yokota180sx
ace, you and i know thatbut 90% of this site doesnt
AceInhole
homeslicej2 wrote: uh, doesn't matter. If you drop an S13 (don't know about S14's) more than an inch, you bottom out the suspension, misalign everything to the point that you need adjustable suspension pieces to get it right. The Eibach springs lower more than an inch (prokit and sportlines). Yokota is right and anyone with a lowered 240 can attest to this as well.
You can drop an S13 a few inches and still bring everything within reason. Sure you'll have a decent amount of bump-steer and anti-squat... but that still has absolutely nothing to do with reducing bushing bind at normal ride height.
yokota180sx wrote:ace, you and i know thatbut 90% of this site doesnt
Well... aren't us here to learn people good, I thinked?
yokota180sx
while bantering of course
homeslicej2
ah, gotcha
