Lowering a Q45 G50 series
NICO's V.I.P. styling forum.
mechanikdan
Car: 240sx convertible
Is it impossible to find springs in the US for a G50 Q45. I know most of the companies phased out the application ages ago. Anyone have some ideas. Just picked up a mint 1993 Q I am putting back on the road.
unknown007
Car: White 1993 Q45 (G50)
I did the Z32 suspension swap.One thing to know is that the rear Z32 struts will not lower the rear or the Q and will give you a hot rod/muscle car stance.Do what thejapino did in his rear and use the fronts.Or once again go with coilovers.
Damicci
Car: 1994 Q45/President
unknown007 wrote:I did the Z32 suspension swap.One thing to know is that the rear Z32 struts will not lower the rear or the Q and will give you a hot rod/muscle car stance.Do what thejapino did in his rear and use the fronts.Or once again go with coilovers.
I had no problems lowering my rear. I didn't lower it more as I would have needed to roll the fenders.
If you search there is a guide on using the Z32 coilovers. If you don't mind having your front slammed 24/7, then it works great, i got sick of replacing tires and fixing s*** cause of debris on the road so i sold mine.
Edit yes there are adjustments you can make and buy uca to accomodate the camber but i didn't feel like it so selling was a better option for me at the time.
unknown007
Let me rephrase that.OEM Z32 suspension.
Damicci
unknown007 wrote:Let me rephrase that.OEM Z32 suspension.
ah ok.
mechanikdan
so use z32 fronts on the front and the rear....are we talking OE stuff or aftermarket like lowering springs and struts for z32....
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
You can do it either way. thejapino's Q looks sick. Also, I'm about to go to air, and I might be willing to sell you my Eibach's. Cheap. Plus, you can always look for Espilir springs. Just some ideas.
mechanikdan
im game on eibachs. i just want a bit of the gap gone.
unknown007
I'll take pics tonight of my car.The OEM springs are used with new KYB just so you know your struts wont blow. The front drops to a 3-3.5inch off ground drop with in the front.If you put the OEM springs and rear Z32 strut it won't drop so like I said if you do that custom fabrication that thejapino did then your set.Or you can get Eibach sleeves.I went a cheap way on sleeves just because I can and damn is my car bouncy as hell. Just went sleeves in the rear and have OEM springs in front.Don't do what I did it's bad.I just did it so I don't bounce around.
My suggestion set up a deal with jitibbs and wait for the springs.Unless you wanna do the swap.
BLACKonBLACK98
Car: Q45, LS400, STS-V
sounds like the best option for your needs is just waiting on some drop springs to pop up. for your goals the z32 coilovers are too much money, the z32 oem is just a bad idea, and * dampers with custom mounting sounds like too much work if you just want a mild drop.
mechanikdan
terrible photo of my project
BLACKonBLACK98
make it happen. ha ha.
gl with whatever you decide. wanna trade tcu's? lol.
unknown007
Yeah gl.Most setups here will have their bads and good but just wait for springs is the best bet.
thejapino
Car: '93 J30t
Here is my thread:zerothread?id=314402 Here is another w/ my opinion on my old setup:zerothread?id=405001 Here is pics of the old setup:
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
thejapino wrote:Here is pics of the old setup
and where's the new setup?
unknown007
it's in his sig!!! I say if you got time and want to do a project go for the Z32 swap. Again the rear Z32 suspension won't drop the rear much except like .5in.Why?I dunno I still have hot rod stance with Z32 suspension in the rear.Best to get them leveled go with front Z32 in the front and rear.Read the threads and good luck.Putting Z32 lowering springs on the swap might drop it too low so I suggest getting Eibach coilover sleeves if you want to go lower but I doubt you will.Oh also you can use KYB GR-2 instead of OEM.
audiovisiony33
Car: 1997 Infiniti Q45
No worries about the springs. I just post my last two sets of ESPELIR for sale at the classified that I imported from Japan for PG50/G50 90-96.
I only have two sets available for sale so grab them while they are available.
TBrack
Car: none
z32 coilovers are cheap and easy to throw on if you are serious about lowering your car
Return to “VIP Forum”
