Thx Jeff... I plan on shimming the fronts with flat washers, but am not sure if the same can be done with the rears.Jeff Williams wrote:If you don't have adjustable upper links, then kiss your tires goodby. You will not be able to get the front-end aligned within specs without adjustable links. Same thing on the rear, you need adjustable upper linls.
You should'nt have a problem with wearing out your tires with a drop from springs.As long as you have your toe corrected.You can also correct your rear camber with the stock adjustment bolt if you want.Im running almost 4 degrees of - camber in the rear with no wear problems.Front about -2.75 with minimal wear.DrewQ45 wrote:
...Drew...
Might check out Q45tech's post on lower outer tie rod joints also from a Z32 to reduce wear from lowering.DrewQ45 wrote:Don't think I'm not tempted!
What do the Z32 tie-rods do that a Q45's can't? They are both adjustable for toe. My tie rods (inner and outer) are relatively new. I'm trying to keep costs down and not buy a whole bunch of $ht just to lower. I might not even like it and wanna switch back. Pursuant to that, you can acquire my springs if all goes well.maxnix wrote:Might check out Q45tech's post on lower outer tie rod joints also from a Z32 to reduce wear from lowering.
I may be interested in your springs if you do lower as some day I hope ot have some made up that are stiffer but don't drop more than 1/2".
Thanks man... good advice.sijoko wrote:You can get the spring compressor from Autozone for free. You pay them the money for it and when you return it, they refund everything.
When you install the new springs, pay attention to the orientation of the studs on the hat. Otherwise, you'll find that the mounting points don't line up and you'll have to compress the spring again to rotate the hat.
After you lower the car, you can adjust for camber in the front by using 7/16" washers behind the upper link mount. Try to get the ones that are consistent in thickness. I found some at Autozone that are very good quality. You have to put an equal number of washers over each bolt. Also, don't put so many that you don't have enough thread engagement after everything is bolted up.
You should measure the camber before you do anything. You might find that one side has more than the other. This will usually be the case even after the new springs are installed. For my car, two washers per bolt moved the camber .5 degrees.
I've got a digital camber gauge that racers use. That plus a toe bar allows me to do my own alignments.DrewQ45 wrote:
What did you use to measure camber? Any adjustments to rear?
