Lowerin the A/C question.
A_C_Fanatic
Car: 2.5 S Altima Coupe Azure Blue. 20% Tints All Around (they seem darker), Stillen Cat-Back Exhaust
If i lower my A/C would the pickup of the car drop? and wat aare the advantages nd dis-advantages of lowering a car?
chow
Car: Altima coupe 3.5SE
lowering.. i would assume acceleration would either stay the same or get better slightly.-Cornering will be easier at higher speeds-Looks cool
Cons:- If you live where i live = snow, you may run into some troubles. Im still deciding wheather or not to drop my car b/c snow gets really high sometimes.- Might hit curbs when opening doors- Suspension gets worn over time- Id assume you have to take it off when reselling to dealer.
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
A_C_Fanatic wrote:If i lower my A/C would the pickup of the car drop?
What do you mean by this? Are you worried about the acceleration off the line? Generally from a standstill, lowering the car reduces "squat" on a hard acceleration.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
you will reduce wheel hop, if you have a maunal. the accel wont change for the worse thats for sure.
