blueovalz »
https://forums.nicoclub.com/blueovalz-u25800.html
Wed Aug 23, 2006 3:31 pm
The comfort is not as much of an issue as hitting the bump stops or the top of the spring perch in a corner and losing it. Right now, I've got about 1" of compression travel (with stiff springs), and that's spooky in the wrong situation. I would just like to get the strut set back to the middle of it's travel window at the current static ride height. It was easy for the Z. Perhaps I could use the same Koni 8610 inserts, and modify the strut tube in the same manner as I did with the Z. What to the racers do, as surely they don't run the road courses with the strut compressed this much, do they?
