lowered front-end on 95 nissan hardbody
chappy63
Car: nissan hardboby
I am new to the forum. my son has a 1995 hardbody that we lowered. Since we lowered it, it is eating the front tires. Can i get the alignment close without taking it to the shop. I shimmed the upper a-arm, put it didn't help much.
jdansmith
Car: 2008 Sentra 2.0S, 91 Sentra 1.6DHOC, 89 Hardbody Z24
Mine ate them up on the inside of the front also and its not lowered. I've only put about 400 miles on it since I've had it but I'm gonna let a shop figure out whats going on.
Laydout
Car: 89 nissan hardbody
Well I doubt u take my advice but I say bag it then he can lift the front while drivin..but I'm pretty sure u can get it back right without takin it to a shop..just call and ask about one and say how do y'all go about doin one then when they tell u just do it yourself lol
PEZi
the part that is eating your tires is the toe being out from the lowering... you can try to get it back near 'good range' and it involves measuring the distance from the centerline of both the left and right front tires in both the front and back of each tire... and adjusting until the front of both tires is the same distance as the rear of both when measured from the centerline... hopefully that made sense
the upper arm is for camber... i can tell you from experience camber isn't what eats tires... its the toe
i should add you should ALWAYS go to a shop for toe alignment... but no one is going to force you to do so
***edit***... here is a pic of what the tires are doing... not as noticeable in person as in the picture... but basically you need to make them both point straight again
