lower stabilizer bar W/ rb25
perkeset
Car: 1993 Nissan 240SX
we have succuessfully intalled the rb25 and it runs well, we are having trouble with the lower stabilzer bar. it hits the oil pan, so we made some brackets but the all the railroad tracks and ****ty roads arouns here have broken the welds. how has everyone else fixed this issue since w/ the rb25 the stablizer bar does not clear the oil pan?thanks -J
240z4u
Car: '95 Nissan 240SX
No fitment problems here.
Maybe weld up something nicer/stronger.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
how did you mount the motor? mount kit, r33 xmember, etc?
integra7
Car: 1995 Nissan 240sx
I am using the R33 crossmember and the oem sway bar did not clear the oil pan. So I got the whiteline sway bar and it clears just fine.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
i am using mckinney mounts and it clears. Under really hard cornering it has made contact, so I will be adding some really small spacers to give it some better clearance. I haven't seen one in person, but whiteline makes a bar that dips down lower than the stock bar at the oilpan. That might be a good choice for you.
