Steve Lloyd »
https://forums.nicoclub.com/steve-lloyd-u36254.html
Tue May 08, 2007 1:33 am
there are going to be be some extra connections. One for the O2 sensor, and one for the CRANK sensor. The KA speed sensor will repace the SR speed sensor on the SR transmission. The lower KA harness plugs into everthiong else on the SR. You need to be careful when you put the feamle grond connector on the starter, the KA plug is a little lose.
The speed sensor is at the tail end of the transmission. If you don't have the KA sensor, then your speedo won't work correctly.
