lower shift boot tear
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys
im preparing to install my B&M and upon removing the shift boot and the rubber boot below it the bottom most boot that holds the shifter is torn, and i can see inside where the c-ring and the connections are its kinda oily and its oily around it too, is that the transimssion oil thats around it or does it have its own oil. because im thinking maybe some leaked out that way then and i should check if its still full
o_O
tnx
max
themadscientist
transmission oil, get a new boot.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
yeah i put the b&M on now so no more leaking out.. dono how much came out ill prolly check soon and add some
max
nismojunkie
how do you take off that botom boot on a stock shifter? does the shifter come apart?
hachibroku
Car: 98 240sx s14 MO Betta
it should just pull off to get the shifter out you need some snap ring pliers to get the snap ring off and then it just pulls out you cant really take it apart.
gumby
Car: '89 240sx sohc
to get the new lower shift boot on yoo unscrew the shift knob, lube it up, and pull the boot over the shifter from the top down. it will stretch more than a woman giving birth.
