Hello , i picked up a 2002 Altima from a friend of mine . All seemed well but i noticed a couple days after i got it that the upper radiator hose would go almost flat after i turn the car off and it would sit for about 10 mins or so . I made sure the overflow tube was clear and replaced the radiator cap and bled the air out --- which fixed that issue .
Now , after fixing that , i been watching the car alittle better and noticed the lower radiator hose stays quite cold and the upper hose is hot . The heat seems to work fine and it doesnt appear to be overheating . Ive not driven the car very far out of concern of the lower hose being much much cooler then the upper . After reading i see there are 2 thermostats , If one is the issue , would it be the lower one since the lower hose is staying cool ?
