Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri May 23, 2008 10:02 am
WC, you can buy the switch from Nissan seperate or it's included in the lower rad hose/sensor housing. I think for the whole hose and switch combo, it's about $50 or so through Nissan.
You'll need to set it up so it turns a relay on, though. The switch can't support the current needed to run a fan, so you'll burn it up pretty fast
Also, remember it's designed to be in the circuit in the lower rad hose, so it's temp setting is set for after the radiatior has cooled the water.
