lower radiator hose help!!
Eikon
Car: 71 240z, 93 Supra TT
What hose are you guys running for your lower rad hose? I tried a stock KA hose, but it's nearly impossible to get to fit over the tstat housing..
My sob story:So I spent a ton of time and energy removing my intake manifold, replacing the tstat and replacing the lower radiator hose. What a pain!
I had it all back together, took it around the block.. not a drip!Had it up to temp idling in the garage for a while.. not a drip!Started to go back out for a drive in the nice weather! pop.. sploosh.. i got coolant all over the driveway.
Must be the lower rad hose that busted again.
So I have to do the whole damn project over again..
What hose should I use this time? Anyone know of a good one? Anyone have a stock number?
krayton
spit on it. lube that ish up
its a known issue that its hard to put on. always suggest to people to put it on before the engine goes on. but just lube it up and jam it on there.
gonna take some elbow grease
*using stock ka
blurrbosi
Car: 240's
cant you use the Z32 rad hoses... i thought it was easier to put on.... but that might be with the dual can KA rad.... Throw some lugy on that hose...
Eikon
I thought I had it on there tight... tight as hell actually.. with two clamps tighted as much as I could get them..
I wonder if I put too much stress on the rubber trying to stretch it out to get it on there..
I gotta try something other than a KA hose.
krayton
was it a worn KA hose?
try getting a new one.
telling ya man, lots of us just use the ka lower radiator hose.
Cpt_Impossible
Car: G35 6MT
http://www.tweakit.net/shop/in...2_602
I just got mine in the mail today from Tweakit.net, an aussie skyline shop. The stock RB20 one I recieved looks to be expanded at the thermostat kneck to fit. That is probably your problem.
Eikon
Cpt_Impossible wrote:http://www.tweakit.net/shop/in...2_602
Ah.. that's what I was hoping for.. except for the fact that it has to ship from overseas.
krayton wrote:was it a worn KA hose?
Brand spanking new hose from advance auto. Had a HELL of a time getting it on.. had to grab an old bottle of wine and force it over the end and push it up the glass bottle to stretch the end and then leave it overnight.. the next day I finally got it to slip on.. pushed it as far as I could up the neck and then screwed it down hard with two clamps..
I'm wondering if it crimped a little in the center since it wasn't a perfect bend.. then built up pressure and popped off the tstat housing neck?.. Or perhaps I stretched the rubber to hard and it burst somewhere (seems unlikely).
I think Neal can get me a R32 GTS hose from Japan. Hopefully that will solve it for me.
Thanks for the input you guys!
Cpt_Impossible
Car: G35 6MT
The shipping from Australia took 10 days including a weekend.
240z4u
Car: '95 Nissan 240SX
Stock lower here.
Are you sure your radiator cap is working etc... something else besides the hose could be the problem.
Surprises me you would blow off/ blow up a lower hose. I haven't really seen that problem on the boards.
Evan
Eikon
well.. I just put in a brand spankin new thermostat.
maybe the rad cap is bad.. I know that I didn't get any flow to the overflow tank. I'll get a new one just to be sure. Good call Evan.
integra7
Car: 1995 Nissan 240sx
240z4u
integra7 very sweet. I never saw that.
Eikon, are you sure you did not put your new thermostat in backwards or somethin crazy??
Make sure your radiator isn't plugged too.
Evan
Eikon
I'm pretty sure the spring goes to the inside of the motor... Not that I haven't done dumber things in my life, but I'm pretty sure I got the tstat on there correctly.
240z4u
Defective T-stat is always possible dude.
Good luck with the solution.
Evan
BTW..... I am running the oem ka lower hose I had on the car, of unknown age.
DJButton
Car: 2010 Nissan 240sx
I'm running custom ghetto rigged hoses from Advance, just brought in my RB20 stock hose that had a big slice in it and matched as best I could to similar hose out back. For my upper rad hose I have one of those metal wired laced suckers just cause.
skribblah
go to autozone
order 1996 300zx lower rad. hose
one end of hose is bigger (for larger RB) and other end is smaller to fit in rad.
cut as needed.
:] worked for me.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Now see, why go through all this worry about whether or not this hose or that hose will work?
Seth, hose is ordered and I'll pick it up in the morn, along with your gasket.
-Neal
DJButton
Neal's the man, period... wanna pick up a lower hose for me Neal? heh
Eikon
DJButton wrote:Neal's the man, period... wanna pick up a lower hose for me Neal? heh
Neal rules!! Thanks buddy!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
I can see if they have another one in stock when I get Seth's tomorrow. They are relatively cheap, but I do charge a commission. 1000% on anything below $50...LOL
Nah, I'll see if they have one in stock.
NOTICEThis does not mean I will do this for everyone. As I am only going to make one trip to Nissan in the morning as it's a bit of a drive.
Reaper
Car: 96 & 91 240sx
I used the Samco hoses upper and lower and they fit with minimal trimming. I'm rb25 though just get the samco's that fit the rb20 and trim them as needed.
Britt
Car: 1995 240sx se
Reaper wrote:I used the Samco hoses upper and lower and they fit with minimal trimming. I'm rb25 though just get the samco's that fit the rb20 and trim them as needed.
X2
DJButton
Neal, would be very happy if you did, mine kinda scares! 1000% of something is better then a 100% of nothing right? lol
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
DJButton wrote:Neal, would be very happy if you did, mine kinda scares! 1000% of something is better then a 100% of nothing right? lol
Sorry man, no go. They didn't have one and wouldn't let me order another one. I tried for ya.
Seth, have your hose and gasket sitting in my bed room. I just need to find a box long enough to put the gasket in. I'll have it out by Saturday at the latest.
DJButton
Thanks anyway Neal, much appreciated.
