lower oil pan gasket 2004 G35
owenscountry
Car: 2004 Infinity G35X
I am going to chan ge the lower oil oan gasket and it looks fairly simple. Does the gasket require gasket adheasive? didn't look like it did but need to make sure. Thanks in advance for the help!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Yes you need to use High Temp RTV.
owenscountry
cool thanks
owenscountry
do you know if there is a DIY for the upper gasket just in case
RED_DET
Vendor
2011 Infiniti G37x
The upper gasket will be a little more in detail, but straight forward. The RTV can be used by itself to create the gasket and seal everything like it needs to be.
