Lower intake mani Gasket
S13FX
Car: '69 l20b Dimeski :)
Can I just use copper gasket maker for the lower intake mani to the head?
480sx
Car: 1996 Pearl White 240sx
The paper type gasket that your supposed to use is really cheap you just generally have to special order it. I would vote against using liquid gasket for that, since its a flat on flat surface. Also your engine sucking up the pieces of gasket that will squish down and rest in the insides of the intake manifold cant be good.
For as cheap as that gasket is theres no reason not to use it.
