Lower Intake gaskets....which side up?
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
Starting on installing the (plenum KS job) lower intake runners, and maybe this is a dumb question, but what side of the gasket should face up, the "raised" face , or the "indented" face?
Or does it even matter?
Thanks...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmm...which side matches which part? Call Joe if you have to.
Meaux
Both Gaskets, Left and Right are the same, and can be flipped around either way to fit.
I'm beginning to believe,it dosen't matter......
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
how's this for real time....i pulled the right bank not 15 minutes ago. 'bump' goes to the bottom per old gasket. i agree that it wouldn't really matter.
This IS the way to do it imo. with just the right bank removed, everything will be soooo much easier. i'm planning to leave the walk away renee [lefte banke], but have the gasket just in case.
don't forget to go to your local parts store and change out all the 5/16 high pressure fuel hoses [joe does not carry them as they are not pre-formed].while you are in there.
Meaux
Thanks, I'll carry on......
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
GQ Jay wrote:how's this for real time....i pulled the right bank not 15 minutes ago. 'bump' goes to the bottom per old gasket. i agree that it wouldn't really matter.
Honestly Id do both sides to make sure theyre as clean as can be...
