I am doing an s13 sr - s13 chassis swap. the s13 chassis is an SOHC chassis, and some of the wiring on my lower harness is falling apart.
I have two wires that ripped from some connector (or possibly 2 connectors) . one is brownish the other is black possibly with a grey stripe (if so its like a pin stripe sized stripe)
I have no idea what they go to. I have 1 plastic grey connector going to the alternator, and 2 grounds type terminals also connected to the alternator.
I have 2 total connectors attached to the starter, 1 large terminal type and 1 small connector that just kind of sits on a little flat blade thing (very loose)
I have 1 connector attached to oil temp sender
3 total connectors attached to transmission: speed sensor, and then the two sensors (neutral and reverse) that have to have sr connectors. there is 1 extra connector here.
so far that leaves me with 2 total plastic connectors, and these two mystery wires (brown wire and black wire) that currently have no home. I know at least one of the connectors (extra transmission sensor) is not needed. the other connector I am not sure about and those two dangling wires I am not too sure about.
I have a clip, but I cant find anything with brown and black wires on the jdm s13 lower harness
any help? I will post pics as soon as I can get a camera going
just a reminder its an SOHC chassis.
