s13EastTN »
https://forums.nicoclub.com/s13easttn-u15057.html
Sat Jul 24, 2004 11:45 am
Did you drop the oil pan? I was having the exact same trouble a couple days ago. Take all the bolts out of the oil pan, first remove the front ones(which you have done) then take the braces that help hold the transmission/engine together(about 8 14mm bolts in total, you will see these towards the back of the oil pan blocking 2 bolts in the back and maybe one on the passanger side). Now support the engine with a jack and a peice of wood by jacking it up where the transmission meets the engine(next to the braces, and make sure to put them back on before you jack up your engine) and then unbolt both motor mounts on either side, driver side is a tad bit harder than passanger. Some people say only the passanger, and I would try that first and see if it works, but it didn't for me. Now you will need to unbolt the remaining 10mm bolts that hold the oil pan off, then it should hopefully fall down. Still not out of the fire yet, as there are 2 12(?) mm bolts you need to unbolt from the oil pump. You see, the reason it is stuck is because your oil pump is mounted on the inside of your front cover, and the pump has an oil pickup that goes way down into your oil pan. If you get the 2 bolts holding the oil pickup off of the oil pump, then check and make sure you have all the bolts loose(and by the sound of it, you do) and then pry it off. If you need any specific questions answered just hit me up on aim :reddragonhcivic
hope i helped
