Lower End Bolt Kit
SC90S13
Car: 1990 Nissan 240sx
A while back i came across a lower end bolt kit, for the oil pans and a couple other things for the SR20det, only problem is i cant remember what site it was on. All i can remember is it was about 89.99 for the kit. Any help would be appreciated.
SSonic92
Car: 1995 Nissan Altima almost done..
1990 240sx-swap almost ready to go in:)
Check out frsport.com or enjukuracing.com, they should have what your looking for which is called a main bolt kit.
SC90S13
Nah i dont need the main bolt kit, its a kit that i saw that came with all new bolts for oil pans, and the timing cover, water pump... i just dont remember where i saw it. I believe it was $89.99. Thanks for the help tho
SSonic92
O ok then, my misunderstanding. If u do remember where you saw it post it up, i might see about getting that also.
SC90S13
will do
SC90S13
I FOUND IT!!!!!!!! :bowrofl: IT WAS ON MAZWORX IM A DUMBASS WOOO :facepalm:
http://www.mazworx.com/product/aestheti ... e-bolt-kit
:woot:
