lower control arm
dhicks02q45
Car: 02 q45 base
i have an 2002 infinity q 45 base and the bushings for the front lower control arms (left and right) are leaking oil. the new ones from the dealer are 379.00 each. ouch!!! are there any other options? can i just replace the bushings?
qship96
Car: 1996 Infiniti Q45
Sure thay are not tension rod bushings? I dont recall the lower control arm bushings being silicone filled?
dhicks02q45
Car: 02 q45 base
hello and thx for replying. i was told i need 2 lower control arms, when i asked why they showed me where oil(it looked like) was leaking. it was leaking from the part has a big rubber part at the end of it. the diameter of the part that was leaking was about 5in and it was both arms...
qship96
sounds like tension rod bushings to me......google it and then click on images and see if you can identify it.
dhicks02q45
Car: 02 q45 base
ok
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
http://www.dapcwiz.com/forsale/tension_rods.jpg
Do they look like that?f so those are tension rod....
dhicks02q45
Car: 02 q45 base
u know they do look like those...are those connected to the control arm?
240RB1
92 Nissan 300ZX Z32
Yes the tension rods are connected to the lower control arm by two studs with bolts.a cheaper and in my opinion better alternative would be to buy adjustable tension rods-they are solid and are able to adjust caster with then and have no play so they will for the most part never wear out.i know you can use 240sx and 300zx tension rods on older q45's but not sure on the newer ones,il see what I can find.
dhicks02q45
Car: 02 q45 base
thx for chking
240RB1
92 Nissan 300ZX Z32
Well I personally searched for stock and aftermarket and came up with nothing....sorry bro,I'm sure someone else will chime in.
dhicks02q45
Car: 02 q45 base
i hope so..dealer wants 379.00 ea and my pocket book isnt trying to hear it...lol
OwnerCS
We just need to find some of these babies for a 2002 at $58.04 each.. I'm not having much luck finding some for a 2002 as it is so new..
http://www.amazon.com/OES-Genuine-Radiu ... B001G7HPQS
dhicks02q45
Car: 02 q45 base
yes im starting to wonder if im gonna be able to find them at a reasonable price.
OwnerCS
Coincidentally, I saw a silicon grease drip from one of my lower bushings. I bet some will be in my future sooner than later.
OwnerCS
OwnerCS
OwnerCS
OwnerCS
qship96
dhicks02q45 wrote:yes im starting to wonder if im gonna be able to find them at a reasonable price.
You shoild be able to order just the tension rod bushings from www.everythinginfiniti.com and have your local tech press out the old/press in the new bushing into your existing tension rods.....go to the website and get phone number and CALL them to inquire about the cost of the bushing.....they were only $30-35 each when I last ordered mine for the 96Q. Your local tech should only charge you around $15-20 each to press them in while the car is already on the lift for other servicing like an oil change,etc.
