lower control arm
1995Q45havoc
Car: 95 Q45
hello everyone.. im new to this so i hope this is the right way to ask this on the computer...i have a 95 q45 the balljoint on my passenger side lower control arm is bad..well i cant replace the balljoint because it come only as a hole piece lower control arm an all for $356 i dont have that kind money rite now anyone suggest a way i can get around paying that much thankyou feedback will be very well appreciated
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Well you can call Autozone or some other cheap auto part store and see what they have for prices OR call Infiniti of Scottsdale and buy it from them for $298.23 shipped to your door.
http://www.infinitipartsusa.co...d%3D1
But How bad is the ball joint?
Who is going to do the labor?
Welcome to NICO
Please update your profile.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you price at
http://www.infinitipartsusa.com
$356 seems not much every 180K or so, if you set a side a penny every 10 miles for it.
People don't understand tehy are driving a $56K car in 1995 dollars. No further discounts on parts or labor because of age or current Book Value for Beaters.
unknown007
Car: White 1993 Q45 (G50)
I don't care if people disagree but I say go to the junk yard and buy the lower control arm.I replaced both my driver control arms for about $150 including the toe arm.Maybe they'll let it go for $75 check it out.Just make sure the suspension on the car is in good shape and not bent.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If you have more time than money and don't mind repeat labor sooner and if you're feeling lucky.....well, are you?
Infinitiguy19
Do you know what a ball joint is?
You do know that there are rubber components in the lower control are as well as metal, But using old rubber is like child abuse.
Rubber ages with time and not miles.
Would you use an old rubber or some one else' old rubber for that matter.
Sorry my response was meaner than brian's
unknown007
So your point?You can replace the rubbers on the arms.I still stick to used good ones. You choice,your budget,I gave my suggestion good luck.
Q45tech
After 7 years [warranty expiration] a heavy V8 rear wheel drive car goes thru about $1000- $1500 worth of replacement parts per year on average.
Junkyards work great until the cars are 10+ years old when the rubber isolators may be as bad as what you are trying to replace unless all the parts are bagged and stored inside of warehouse.
Nice thing about 1990 is you have 90-96 to chose from unfortunately we are now 3 years beyond the goodnesss point of even the newest suitable model.Even new parts are compomised if made back in 1995.
Consider if you would SHOULD even buy a brand new tire made in 2000 or even 2005 and stored inside. Those nasty little ozone molecules eat rubber and change it from the inside.
Most smart socialist EU countries and Japan have inspection laws to protect the public from junkyard parts and the general aging of cars.Makes driving expensive and promotes the purchase of newer and new cars to support their domestic car companies.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:Most smart socialist EU countries and Japan have inspection laws to protect the public from junkyard parts and the general aging of cars.Makes driving expensive and promotes the purchase of newer and new cars to support their domestic car companies.
Shhhhh! The Socialist Nazi in Obama's camp will hear you!
Well, I guess Hitler was "change" too.
1995Q45havoc
Car: 95 Q45
I bought the car from a old lady the car was garage kept for 8 years after her husband died basically just sat...i picked the car up with a tow truck i have done all maintanace to the car to get it perfect lets just say bout $1000 later cars premium only has 70,000 miles on it...im going to uti to become a mechanic so i take every dollar i have an use it to the Q i love the car but im really kinda broke at the moment its a recession i heard a z32 lower control arm would work is that true an if so where can i get one.
qship96
Car: 1996 Infiniti Q45
70,000 miles sounds early for ball joint failure, especially for a garage kept car in florida? Maybe accident related damage? Most make it over 200,000 miles.
slybydesignq45t
Car: City Bus
I went to the junk yard and found a slightly used on for my previous 94. It cost me $75 to replace. Its about what your pockets look like. I didn't have $500 either to replace it so I rolled the dice and got 4-5-6. I would trust a salvage yard with things like Air Mass Meters and Fuel Units but other things can be had at good rates.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
slybydesignq45t wrote:I went to the junk yard and found a slightly used on for my previous 94. It cost me $75 to replace. Its about what your pockets look like. I didn't have $500 either to replace it so I rolled the dice and got 4-5-6. I would trust a salvage yard with things like Air Mass Meters and Fuel Units but other things can be had at good rates.
That's what I usually do. Grab multiples from the junkyard. I figure even if I have to replace the used part in a year, I'm still getting away cheaper than with a new part with the only cost being a little effort.
unknown007
I did the same!
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
I bought my Q with slightly under 70,000. Plenty of rubber parts to replace from sitting and time.
1995Q45havoc wrote: i heard a z32 lower control arm would work is that true an if so where can i get one.
z32 ball joints supposedly work.
Search.
zer...82244
captainluigi
Car: 1996 q45t
If you will search my posts you will find fairly detailed directions on how to replace the BJ. Not so tough if you posess basic mechanical and analytical skills.
